Video Cameras Logo
A
Alfredo Peralta Posted on Apr 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need instructions to operate a Sony DCRTRV20 camcorder
Tony Parsons
Level 3:
  • Sony Master 6,405 Answers
  • Posted on Apr 27, 2017
Tony Parsons
Sony Master
Level 3:
Answers
6405
Questions
Helped
1652072
Points
20272
1) point camcorder at subject.
2) press 'record'
Dcrtrv20 windows 7 driver
http://esupport.sony.com/US/perl/support-info.pl?template=&info_id=544
No drivers needed. Window 7 does not support streaming. All info in the Sony link above.
I can not download my Sony DCR-SR42 camcorder. I need step by step instructions.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows or Macintosh as the operating system, then Hard disk as the camera type, then select the type of connection (USB). I list of step by step instructions will then appear.
I am not allowed to cut and paste the Sony instructions here for copyright reasons.
Jan 18, 2011 • Cameras
1helpful
I dont now how the camera works.
You need to get user/ instruction manual copy of camera to know about its features and operational details.
Click Sony Support link to download instruction manual free copy that has all details about Sony DCR-PC115E camera, it will help you operate camera.
Thanks.
1helpful
I have just purchased a Sony DCR-HC51 camcorder 2nd hand and need an operating manual (in English) Please.
You can download and print the instruction manual (English) in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
2answers
I recorder my video on non- SONY DVDs. Now the video is showing only on the camcorder but on other medias like my laptop and DVD player it is showing as a blank. Is there anything I can do to correct it or...
It may just be the format that it was recorded in. Try downloading vlc player then try to play the video from the dvds. You can download it here:
http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html
How to record at the start and how to finalise and view in the computer
You need to Finalize the Recording in the Camcorder so that the DVD can be run in any other device like Computer or DVD Player.
Check this Link to download the Operating Instruction Guide.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRDVD108
In the Operating Instruction guide refer page # 44 fro the instruction to finalize the disk.
Refer the Instruction Manual to use the Camcorder.
Good Luck!!!!!!!!!!!!!!
Need to transfer video from my sony handycam to my pc
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE:As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!!!!
When recording it shows that it is recording but we can't see anything. If we play back what we think we might have recorded we can only hear the sound but not see anything.
Follow the steps below to troubleshoot this issue.
IMPORTANT: If additional model-specific instructions are needed to perform any of the steps below, refer to the operating instructions of the camcorder. The instruction manual is available in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Ensure a fully-charged battery is inserted or connect the AC power adapter.
  2. Turn the camera on to the VTR or PLAYBACK mode.
  3. Insert a cassette tape with recorded video into the camcorder.
  4. Ensure the cassette tape is rewound to the beginning of the video recording.
  5. Begin playing the cassette tape.
  6. If your camcorder has an LCD screen, try adjusting the brightness or contrast.
  7. If there is still no picture on the LCD or viewfinder, reset the camcorder to factory specifications
I had a power surge and my sony dcr-trv350 will not trn on is it worth fixing?
Follow this procedure to troubleshoot if the camcorder will not turn on.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
