SOURCE: error message on recumbent bike
The problem might be the gearbox. I know because I have the same problem. Keys fitness is out of business, but "The Treadmill Doctor" has purchased the inventory of parts for the bikes. They will help you troubleshoot, and have parts available if you need them. The number is 1-888-340-0482. Or, you can go to treadmilldoctor.com.
SOURCE: i need a manual on my stamina r360 recumbent bike
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
SOURCE: schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
SOURCE: Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays
"E3" error code
Check data cable integrity All wires in cable should be intact. If any
are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
SOURCE: I havea new balance 1400 I keep getting two error
Hi This is dinesh here,
The E1 Error is for the sensor problem and the E3 error is for the IC crasg in the machine...
Recumbent bike works best for elderly people with back and hip problems
because of the relaxed position and the angle that put's less pressure on those
areas. Upright exercise bike works on more areas than the recumbent bikes
including the lower abdominal muscles.
