SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
SOURCE: my sanyo washing machine does
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine.
(The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
SOURCE: Would you have a user
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
SANYO Owner ManualsTo find an Owner Manual for a SANYO product, enter the model # of the product below.
Please Note: We are in the process of upgrading the Owner Manual search to also include discontinued product documents. Please check back in a week or two if you need an Owner Manual for an older SANYO Product.
Model # ASW-F6OAT
Search Results
Sorry, could not find any documents that match your search criteria
SOURCE: my washing machine wont spin
Sounds like the belt broke on your washer.
Easy to replace and not that expensive.
SOURCE: Hi my Sanyo ASW-90WRTP washing machine will only spin when its empty.
Bad belt or tensioning device. Possibly a broken spring.
Bad motor but unlikely.
Check your Owners manual troubleshooting
Several appliance parts websites, usually they are very helpful for
DIY.
Could you please solve my problems about E2 error on santo ASW-180 SB Washing machine
Change the water level sensor
