The scanner lock button on the Kyocera TASKalfa 4012i is located on the left-hand side of the machine, towards the back of the scanner unit. It is a small lever that can be turned to lock or unlock the scanner unit.
To solve the C3100 error on the Kyocera TASKalfa 4012i, you should first check to make sure that the scanner lock is in the unlocked position. If the scanner lock is already unlocked, the issue may be related to the scanner motor or the scanner home position sensor.
In this case, it is recommended that you contact Kyocera technical support or a certified Kyocera service technician for assistance in resolving the issue.
Google
Sep 10, 2015 - 27 posts - 18 authors
Check your apps from Google Play Store > My Apps or Application Manager list. ...My phone details: Kyocera Hydro Vibe model C6725.
Sprint CorporationThis article helps you troubleshoot data connectivity issues on your Kyocera Rise. You may have data connectivity issues if you're unable to: ... Some features and applications require a data connection to work properly. ... Note: Most Wi-Fi networkshave a range of less than 100 feet indoors and up to 300 feet ... Contact us ...
Sprint CorporationThis article helps troubleshoot your Kyocera Hydro Edge slowing, freezing, ... You mayhave performance issues if your device: ... back on; Displays error messages; Isunable to install or update applications ... Press and hold the Power key, tap Power off, and then tap OK to turn your Kyocera Hydro Edge™ off. ... Contact us ...
quit messing with the battery for starters. you want to startup into safe mode. If you can get into safe mode then its a software problem, if not then it is a hardware problem. also if the power cord is plugged in and the battery is out of the computer and the problem persists then it has nothing to do with the battery.
