Basheer Ahmed Posted on Apr 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson style cx7300 printer need reset counter
Two red leed is lighting and printer not running
Tim Rickards
Level 2:
Sergeant:
  • Expert 296 Answers
  • Posted on Apr 25, 2017
Tim Rickards
Expert
Level 2:
Sergeant:
Answers
296
Questions
0
Helped
63611
Points
847
Try unplugging it for a reboot
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
You need to reset your printer, because the ink counter is full,
all you need is to download the Epson Adjustment Program And reset the ink counter back to zero, so you can contineu using your printer
tip
How To Reset Ink Counter On An Epson CX7300, CX8300 or CX9300
You must set the date in your computer to "April 11, 2008" to run Resetter Epson CX7300, Epson CX8300 and Epson CX9300 without error. If do not alter the setting of date of according to rule then software will deleted automatically when running.<br /><br />If you have an error, delete all following entry before you rerun the software.<br /><br />delete registry key: <span style="font-weight: bold;">HKEY_LOCAL_MACHINE\SOFTWARE\EPSON\PTSG</span><br /><br />and delete folder: <span style="font-weight: bold;">C:\adjustment program</span><br /><br />To reset waste ink pad counter Epson CX7300, CX8300 and CX9300F use adjustment program. I have tried this software and this software worked. To run this software without error please follow the instructions above.<br /><br />Here How to use this software:<br /> <ol> <li>Download the adjustment program (see below)</li> <li>Extract the file you have downloaded</li> <li>Go to The extracted folder then click tricks-collections.bat file</li> <li>Now set the date setting in you PC to 11 April 2008,</li> <li>Run adjustment program by click AdjProg.exe file the click accept</li> <li>Click Particular adjustment mode then select destination and printer port then click OK</li> <li>Select Waste ink pad counter from the below window and double-click to execute it</li> <li>Click [Check] button to check current protection counter's value.</li> <li>Then Click [Initialization] to reset the protection counter to the initial value.</li> <li>After finishing, you can change the date back to normal.</li></ol><b><br />Link Adjustment program for Epson CX7300, CX8300 and CX9300F</b> <ul> <li> Adjustment program for epson CX7300: <a href="http://www.mediafire.com/?8wrkugah2mj">http://www.mediafire.com/?8wrkugah2mj</a></li> <li> Adjustment program for epson CX8300: <a href="http://www.mediafire.com/?0xfnrgarvuj">http://www.mediafire.com/?0xfnrgarvuj</a></li> <li> Adjustment program for epson CX9300F: <a href="http://www.mediafire.com/?o020wlaf6te">http://www.mediafire.com/?o020wlaf6te</a></li></ul> <br />
1helpful
How to reset "needs service" on Epson Stylus Photo RX500 Printer?
it's all on my website's resetting page
http://www.the-inkstore.co.uk/frame/pages/Epson%20printer%20resetting.htm
But if you want the info right here and now, it's:
How to unlock your Epson RX500 printer
If your RX-500 printer has stopped printing and can't be reset, you will usually see either a steady red light or alternating red and green lights and the printer will not respond. There may also be a message in your computer status monitor saying "communication error" / "printer requires maintenance".
This is caused by built in software / firmware which counts the amount of prints you've made and stops when the protection counter reaches a predetermined limit, also giving the message that your ink pad is full. You will be allowed a certain amount of overflow prints to the protection topbutton1.gif counter limit, after which the printer will completely stop.
There is software online that will normally reset most Epson printers that have reached this limit and is used by Epson Service Engineers called SSC Service Utility (sscserve.exe), however this does not reset the Epson RX-500 protection counter / firmware.
All is not lost, you can manually reset the firmware using the following sequence of actions:
Close down all Epson programs
Exit all Epson printer programs that may be running in the background or on your task bar.
The quickest way to do this is to press Ctrl, Alt & Del on your keyboard and release, which will open your Windows Task Manager.
Click on [Processes] and a list of all processes running on your computer will appear, look for any in the list that say Epson, highlight it and select [End Process]. Carry this out for any Epson programs running.
Now to reset your printer.
Switch off the printer using the power button.
PRESS and HOLD all following printer buttons: Power, Load/Eject, Stop, B&W, Color and continue to hold until "Init eeprom" appears on the printer screen, then RELEASE ALL BUTTONS.
Next press the Color button to clear the protection counter.
Follow any other instructions given by the printer.
I know this will do it for you!
Glad I could help, just sending your friends and family to our site for ink will be thanks enough.
Kind Regards
Nige
Wast ink counter epson stylus cx 9300f rest
Extrak adjustment you have downloaded
Go to The extrakded folder then click tricks-collections.bat file
Then Click [Initialization] to reset the protection counter to the initial value. Thats all.
After finishing, you can change the date to normal.
Link Adjustment program for epson CX7300, CX8300 and CX9300F
Adjustment program for epson CX7300 : http://www.mediafire.com/?8wrkugah2mj
Adjustment program for epson CX8300 : http://www.mediafire.com/?0xfnrgarvuj
Adjustment program for epson CX9300F : http://www.mediafire.com/?o020wlaf6te
33helpful
TWO RED LIGHT BLINKING EPSON R230X PRINTER
  • You need to reset the printer
  • Download (http://www.mediafire.com/?9njmgwlxqgj) and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
32helpful
5answers
1helpful
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
2helpful
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
4helpful
58helpful
5answers
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
