Did you maybe cross the wires somehow and pop the reverse polarity diode ? If you open the radio ,stick your nose down by the power input and take a good sniff you may smell something burnt,electrically. If you do then get a flashlight and look at the only diode that is near the power input wires ,if it looks burnt ,change it with the same diode but new. Make sure the banded end goes in the direction of the arrow .
SOURCE: cb radios-galaxy dx99v
This has an LED channel display, which is the same as the Cobra 29. You can pick up a new one, there are a few color options available. You need to be very proficient with de-soldering and soldering small parts. You need a desoldering iron or desoldering wic, and no bigger than a 30 watt sodlering iron, any bigger can burn the foil trace, and some solder. You have to open the case, remove the faceplate screws, remove the faceplate, remove the channel selector/pcboard, and the channel display pc board together. Now you desolder the pins of the display, aproximately 20, remove the diplay, insert the new display observing direction (make sure it is face with the decimal to the right place), solder each pin to the pc board, and clip off the excess section of the pins (which is sticking out of the back of the channel display pc board. If you have changed to a blue display, you need to remove the orange or green cover, and replace it with a blue one (I make mine from blue transparant report covers) and hot glue it to the inside of the faceplate where the old one would have been. The reason for this is that the blue light will not shing blue thourgh a green or orange cover, and if you use clear, the display will be extremely bright, and the blue cover will knock down the glare a little. Now just put the radio back together and fire it up.
Now with that said, if you think you may have any trouble with this, you can take it to any cb shop and they should be able to help you.
Any more questions, don't hesitate to email me at [email protected]
Dean Pitts
Rollin CBs
SOURCE: Galaxy DX99V
The RK56 was a good mike until Telex bought out Turner many years ago. Now the audio output is lower than it used to be & it's not a compatibility issue as Galaxy radios have microphone amplifier circuits similar to most other CB & 10-Meter radios. You'd have been better off buying an Astatic 636L or even a generic noise-cancelling mike instead. The only thing I can recommend is to hold the mike on your cheek, close to but not directly in front of your mouth, with the grille facing it & speak in a louder than usual voice.
SOURCE: no power to ignition
Check your ignition switch,it could be separating and not allowing voltage to go to the accessories
SOURCE: Galaxy dx99v cb radio
did this problem occur while radio was being operated? or when it was being worked on? or a result of being worked on?
SOURCE: Installed new battery in 92 Toyota pickup, now I
You have a wire off some where look real good,one may have fell down under the battery or somewhere,or there is a fusible link burned.
