Follow these rules when naming variables:
Note: The variable e should not be assigned as a global variable in Maple code. It can be used, however, as a local variable.
, no programming language stated. this is silly to answer, why do that,
as for hyjackers , start you own post
start with , facts like what assembler or compiler you are using. even makers name of product application.
SOURCE: create a program that will display name five
I have C# logic
in console applicartion,
you will have to write code in main method,
for (int i = 0; i < 5; i++)
Console.WriteLine("your source column required");
Console.WriteLine("Success");
that's it.
You can create part-time or temporary 'Out of Office' automated replies in Microsoft Outlook. These can be set so that whenever you leave the office, an auto reply is sent.
This is useful if you have a high volume of e-mail messages and are expected to reply to them quickly.
You can fully customize your auto reply in Microsoft Outlook 2010.
Launch Microsoft Outlook from the Start Menu.
Click "New E-mail." Click "Plain Text."
Enter the message for your out-of-office reply in the main body of the text.
Click "File," then "Save As." Click the "Save as type" list and select "Outlook Template." Enter a name such as "out of office" and click "Save."
Click "File," then "Info." Click "Rules and Alerts," then "New Rule."
Click "Start from a blank rule," then "Check messages when they arrive," then "Next." Set "Sent Only to Me" in the conditions list and click "Next."
Select "Reply using a specific template," then choose "Specific template" on the next page as well.
Click "Select a Reply Template." Choose the template you already created and click "Open." Click "Finish," then "OK." All e-mails will now have the out-of-office reply. Disable it in "Rules" to switch it off.
Hope this helps
