SOURCE: i need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
SOURCE: Unable to use Bluetooth on HTC Touch
Tab start then communication manager and tab bluetooth.Then tab x.go again start-settings.tab connections-bleutooth and and make sure tha the bleutooth is turned on tick the device visible to other devices.tab x.Then start and tab internet explorer . Your mobile start searching for a device.thats it.
SOURCE: i cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
SOURCE: Jabra OTE3 won't pair with Verzon LG phone. How do
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
SOURCE: I have a LG HBM-520 blue tooth head set and it
Most default Bluetooth Headset Passwords are 0000 or 1234
Testimonial: "tks very much for your help it work i was one 0 short tks for your help"
