SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
SOURCE: Bulova 14k Solid Gold woman's watch. Swiss 17
This sort of information is only likely to be available from an authorised dealer.
If you go to the Boluva web site, you will be able to use their dealer locator to find the one nearest you.
SOURCE: How to remove the back cover of the swiss army
The back will either have a small slot on one edge to pry it off or indentations around the perimeter for a case wrench to unscrew it. Specialized tools are used to avoid scratching the case. You best bet is to take it to a watch shop and let them do it. Most places charge between $3 - $8 to properly do it without damaging the case and they should also change the gasket to maintain water resistance if so equipped. Once you have it open you risk damaging the movement as you change the battery. It's not that it's a tricky procedure but you can easily damage something that will cost a LOT more than $8 to fix if you don't have experience.
SOURCE: Good morning. I am considering
The repair to the winder may be only £30.00 but will the watch then work well.Parts for old Omegas can cost a premium and the watch may need a service.A service to an Omega by a good watchmaker will cost £170.00 ish and if it needs parts this will rise.
As to value if its 14ct on a bracelet the gold is worth about £12.00 a grm so if its 30g then the gold is £350/£400.00
Its hard to say what to pay without knowing if the watch works well,if it needs £200.00 spending on it the value is reduced to little more than the gold value so id weigh the watch work out a gold value and then a small amount.
If you need a repair try www.rolexrepairs.co.uk they offer a free estimate.
Regards
Testimonial: "Thank you for responding to my query. I have since found out the bracelet is not white gold. Based upon your expertise, I am not pursuing this further"
SOURCE: i want to know the
It's rarely possible to give any kind of definitive valuation without seeing a watch (pocket or wrist) in person, but it sounds like you have an inexpensive pocket watch that was probably made in the 1960s, less likely made in the 1970s or 1950s. The use of the term "antimagnetic" on the watch, as opposed to "17 jewels," suggests that the watch is powered by a 1-3 jewel pin lever movement, rather than a more expensive movement. These movements can keep quite good time, but they are not valued by watch collectors unless the rest of the watch is of compelling interest.
In terms of value, your pocket watch has more value as a piece of jewelry than as a vintage timepiece. Most watch collectors would not be particularly interested in your watch. In the United States, I've seen similar watches, in running condition, sell for $5-10 at vintage watch fairs. Around where I live (the Northeast), as a piece of jewelry, your watch may be worth twice that but not more. I cannot speak to pricing in other parts of the country or internationally.
