I also have the wrongly designed Samsung SRF 680 CDLS. Ice box problems followed by freezer stopped working all backed up by a company (Samsung) which will not admit that the expensive item they supplied to consumers is faulty . The medium good news , the fridge has been working O.K. for the last year and since Samsung technician inspected the problem and told me the best thing you can do with this 6 years old fridge which cost me $3500 is to throw it . PLEASE BE CAREFULL IF YOU ARE BUYING A SAMSUNG FRIDGE WITH WATER AND ICE COMPONENT.
Jack
Unfortunately my experiences, plural, have all been negative when it comes to dealing with Samsung on the subject of their refrigerators. I own one myself and have been trying to deal with Samsung for almost three years with virtually no success. Their units are unnecessarily complex and I would definitely recommend NOT trying to dismantle your unit yourself. Samsung will use any excuse they can think of to blame your problem on YOU and for the most part will NOT support their retail customers. The internet contains complaints about Samsung that number over 25,000. 'Nuff said
SOURCE: Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
SOURCE: F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
SOURCE: side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
