Question about Panasonic Televison & Video
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
    Master:
  • 604 Answers
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Posted on Apr 21, 2017
2 Suggested Answers
SOURCE:
gopakumarg43
  • 76099 Answers
SOURCE: How do i get my panasonic th37pr9u out of hotel mode..i have a clone box for it and am not getting anywhere..i have tried a few things i found online but no remedy has worked..
To get it out of Hotel mode, you have to enter its service mode option. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the keyword "Hotel mode" & brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Posted on Jun 14, 2015
How to get Sanyo dp50741 out of hotel mode?!
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
Nov 28, 2015 | Sanyo Televison & Video
How do get TV out of Hotel Mode? I have a Panasonic TV Model TH-32LRU20
Change remote batteries. Unplug set and replug it after 5 min. that should reset the devices. If that doesn't work, check the manual that came with the set or go online to Panasonic and look for user guide.
Jul 14, 2015 | Panasonic Televison & Video
Jun 14, 2015 | Panasonic Televison & Video
Hotel mode setting key for TV
Don't know if you've sorted this by now or not but I found this PDF online. It tells you how to put the TV into public mode. Hope this helps 3_29_2014_10_44_37_pm.png
Jun 28, 2013 | Televison & Video
Volume is blocked ("hotel only"). How can I
I found this in another Fixya entry... "-Press Enter and On/Off on the media center , on standby mode -now hold the enter button pressed and start pressing the On/Off button. You should see a setting display on the player. The setting on display should change from video....till...Hotel Control -ON - on that position, press the Volume 'minus' button on the media center. It should change to Hotel Control - Off." My next suggestion would have been to call Bose and ask them why things like this aren't documented anywhere. 1-800-999-2673 Sales support: Mon. - Sun., 7 AM - 2 AM ET Technical support: Mon. - Fri., 8:30 AM - 9 PM ET Sat., 9 AM - 6 PM
REALLY - call them and complain that this is NOT documented online.
Mar 05, 2011 | Bose Lifestyle V20 System - black Theater...
I bought a Panasonic 42" Plasma th-42pwd8 from a hotel. The monitor had the menu, and channel buttons disabled through "Hotel mode". It did not come with a remote. How do I unlock the buttons?
If you cannot find the remote control at all, you will need to reprogram the EPROM IC. This IC is inside the tv, with numbers starting or in between 24c02.... Please contact any qualified tehnican for further help. The IC i mentioned is programmed and at present it is locked through Hotel Mode. Also try to look RESET switch, to reset the whole unit. Thanks
May 15, 2010 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
Hi, I just bought an older model Philips Magnavox from a hotel(Model Number: TL7127C107 Chassis Number: 27B700-7562). The T.V. itself works fine but I can't access all my channels. I did a little research...
sorry, it wont go away, bet ya got it cheap huh(nothing intended by cheap) but the tv hotel mode is telling you that its a special tuner made for just hotels, the only way to get around this is if you can replace the hotel type tuner on the main-board with a normal type tuner, it'll cost more than you paid though.good luck,a friend of mine bought 12 of then at $25 each, boy he thought what a deal, now he's really crying and they didn't tell him,and they won't refund his money
Oct 17, 2009 | Philips Magnavox 27MS343S 27" TV
Need a clone box for multiple Panasonic ct 2522 he televisions
You can get your Panasonic Tv out of hotel mode with the Regular remote control you got with them.
Please follow the steps below.
Press and hold the V/- button on the tv itself.
while you are holding this button down, with the Panasonic remote you got with them press the AV button 3 times.
This will bring up a hidden Installer Menu this is where you can take off the HOTEL MODE. and set up your owe setting.
While you are in this mode, be very care you are not switching things off that you are not sure what they are. as this may put a spanner in the works
Hope you get this all sorted out.
Little Dish Fitter
Please leave a thumbs up if this sorts you out....
Jun 29, 2009 | Panasonic ET-RM100 Remote Control
Getting out of hotel mode
hi have crown tv modle number ctt20001 i think it is stuck in hotel mode
Feb 20, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Televison & Video Logo
334 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
