Indoor pipe thermistor is possibly defective, to check it you must know how to use multimeter or just replace the thermistor.
Have u checked your low pressure and high pressure when compressor is on. Remember the compressor has a thermal protection switch if the compressor has too much freon the A.C will work for a while turn off, then turn then off and on. Are the air filters for the evaporator clean, is the blower fan blowing the correct way. How long ago did the evaporator coil got cleaned. With a properly cleaned filter and evaporator coil you can now check for pressures. Use your ammeter and check how much the compressor is pulling and compared it to the name plate. How much tons your A.C. If you give me how much tons and low and high readings I might help you diagnose the problem. Make sure the evaporator is clean blower blowing correct way condenser cleaned and condenser fan rotating the correct way
