SOURCE: Magnum Force Jacuzzi Pump stopped working
No serviced by pool technician. But you can look in your breaker box for a popped breaker, it should be 20 amp and be positioned in the middle instead of on or off position. Kirk
SOURCE: I have a Jacuzzi Magnum force pump
Good luck...Jacuzzi went out of business. The best source I have had for their parts is CCO:
http://www.jbparts.com/jbc0001.html
SOURCE: Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
