Restart your computer by clicking Start > arrow next to the Lock button > Restart.
As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
Note: You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Press the Down arrow to select the Repair Your Computer option on the Advanced Boot Options menu, and then press Enter. Select your language settings and then click Next.
Log in as an administrative user, and click OK. Then click the Dell Factory Image Restore option.
In the Dell Factory Image Restore window, click on Next. Check the box that reads Yes, reformat the hard drive and restore system software to factory conditions, followed by Next.
The computer will now restore to its default factory settings. Once the restore operation is completed, click on Finish to restart your computer.
SOURCE: I need to reset my
Using PC Restore in Windows XP or Media Center
Notice:
Restoring the original factory image erases ALL existing data. This includes files, folders, programs, drivers, E-mails, photos. Before performing a PC Restore, back up all personal files. If you do not back up your personal files, the data will be lost.
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Restore factory Settings on a Dell Inspiron
hi..
if you have windows xp then you need to turn your computer as soon as you do that before you see the windows xp logo hold down the control key and keep tapping f11 key.it should take you to the screen fro factory settings and if it is windows vista then you can go ahead and press f8 and then choose repair my computer,hit enter which will then prompt you to login in once you log in it will tell you to choose the options from the options listed below choose the one which says restore factory default...you computer will be restored to factory settings..
vedhick
SOURCE: reset to factory settings
If the system has the original Dell image, then just after the Dell Bios splash screen should be a black screen with w blue bar at the top with www.dell.com at the top.
At that screen press CTRL + F11 to initiate the PC Restore program.
SOURCE: how do you reset factory default on dell inspiron
restart your computer when you see the dell screen press CTRL+F11 follow the steps.
if your computer is older then 4 years I think its F8
