Label on bottom of support stand: Item: A60P0774 DPC#056 13 0060 MODEL: DPF710 On/off button on same end as power plug USB and SD ports on opposite end of support stand On the top side of the support stand are 4 buttons: Menu, Enter, Left and Right
SOURCE: Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
SOURCE: 7" Trutech digital photo frame Calendar
Use the Navigation Buttons to select "Calendar"; press Enter to confirm. To set the date, press the Stop Button and then use < and > Buttons to adjust the year and the arrow down and ^ buttons to adjust the month; press the Stop Button again to confirm. Then, use the Navigation Buttons to select the current date on the calendar display and press Enter to confirm. To exit press the Menu Button.
SOURCE: I need an instruction manual for an Acqua Indiglo
Go to Timex.com and see "manuals" at the bottom of the screen. You can download the manual for the acqua and expedition series of watches.
Thanks!
SOURCE: digital umbro watch purchased 2001.How to change
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Thanks!!
SOURCE: have a digital decor 8'' picture frame
I have contacted the company who makes this frame and the first time they sent me a new frame. It has since happened again twice. I don't know why I ever bought a second one. luby3298 is correct....if you turn the on off switch back and forth for what seems like forever it will sometimes come back on. I really wish that there was a way to group together to get this company to refund the money spent or to continue to replace the product. If you type in the model number in google with the word problem or issue you will see that we are not the only ones facing this problem. It only seems to happen when someone shuts this frame off or when the power goes out. I won't recomend this product or anything related to digital decor to anyone in the future.
