My HP d7160 printer requires the initializer cartidges, but i don't have them, how can i start to use my printer, i can't find them, can somebody help me with that?
Am I correct in saying that this printer is not operational unless you have the initializer cartridges?? I'm trying to help someone get this printer up and running but I have no idea where they acquired this printer from. What a pain in the neck.Am I correct in saying that this printer is not operational unless you have the initializer cartridges?? I'm trying to help someone get this printer up and running but I have no idea where they acquired this printer from. What a pain in the neck.
You can't post conmments that contain an email address.
The ink system failure is caused by air in the ink feed tubes. This happens if you allow the ink to fully run out of the cartridge and it **** air in or if you use poorly filled refill cartridges that have air bubbles. To clear the error you will need to perform a purge on the ink lines to clear the air out. We have a step by step guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The process will take about 10 minutes to finish but then you should have a fully functional printer again.
I hope this helps, If so please rate our solution.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then reinstall the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
