I bet you have a nylon bushing that has gotten brittle and disintegrated. Your local Kawasaki dealer should have an exploded view of your machine. Look to where the linkage and cable meet on both ends.
Jun 14, 2004 - I bought a used 550 mule and it has a louder than normal whining noise ... I got a 98 Mule 550 with 640+hrs on it. ... 04 3500 Dodge 4x4 diesel
I am not familiar with the model so I don't know the starter type or how it engages, though if it is making a grinding noise it isn't right and should be removed for inspection.
If it has a pinion that meshes with a ring gear it obviously isn't meshing correctly or the ring gear is damaged. Each tooth of the ring gear must be examined before replacing a starter.
A starter motor is sometimes located on dowels and sometimes meshing is adjusted by shims.
A repair manual can be downloaded at the link below if you need guidance.
This transmission shifted smooth and strong through all gears until today when it stopped all of ... Any idea on where we should start tackling this issue? .... Also, make sure that the pressure tester is not leaking or you will run the tranny dry(use ...
I don't know what you mean3010 mule is this a chevy . If so look at the acuator cable and the actuator it self and the front carrier switch as well as the shifting mechizium switches for the 4 wheel engage system adjustment and vacuum positvve pressure to the transfer case and transmission
