Air Purifiers Logo
How can I reset filters light on hunter air cleaner
2 Related Answers
Anonymous
  • Posted on Mar 23, 2009
SOURCE: lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Anonymous
  • Posted on Feb 25, 2010
SOURCE: Cannot find manuel, need to reset after replacing filters.
How to reset Hunter quietflo air filter, won't start up.
2answers
Resetting filter indicator on Electrolux oxygen air purifier
Hi! I hope this tips might help you out .
*Plug in air cleaner and press POWER button until short “beep” sounds. . Press the RESET FILTER button by gently inserting a paperclip into the RESET FILTER hole on the control panel. The light will flash 5 times before a “beep” sounds to indicate the filter has been reset.
Thank for using fixya .
My hunter 30890 air purifier wont turn on after filter change
Most times the cover has an interlock. Look for something prijecting from cover and the a place where this would fit into. Align cover then close. If you dont see one then look under or behind filter. Also check the filter is installed correctly (direction of airflow). Remove power (unplug or circut breaker) then power back on might reset as well.
Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
Hello, this is Ava with Think Crucial.
Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
Ava B.
1helpful
2answers
Model 30375 replace filter light
There is a "RESET" icon next to the warning light. See the tiny hole? Get a small toothpick or something similar and simply insert, push, and watch the annoying light go out!
1helpful
Lights still flashing after i replaced filter
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • 0helpful
    Air purifier HUNTER 30200
    I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
    On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
    Top Hunter Air Purifiers Experts
    ADMIN Andrew
    ADMIN Andrew
    David Kassin
    David Kassin
    Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
