SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
SOURCE: Leaking power washer hose
most auto stores have high pressure connectors and or machines
to make these connections. Also there are radiant heat connectors
that may or may not fit.
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
SOURCE: Water is leaking from under the chrome piece
Plastic Pump Manifold is cracked.
Can be replace at a local Karcher Service Center,
or if you are mechanically handy.
Replacement Manifold Complete, is available from www.karcher.com.
If it is under 1 year old, and under warranty Karcher will replace if you have a Receipt proof of purchase.
SOURCE: karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
