SOURCE: i recently purchased a sony bravia 46" led hdtv
Adjust the powersave so the screen does not time out. The option is in your menu.
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
SOURCE: sony bravia led 40" blue
That actually happened to a tv of mine once-i had some clear diet soda get spilled on front, I didn't clean it out(just off of screen) and I corroded the contacts on the lcd itself. if it is a recent problem get it cleaned/clean it yourself as soon as possible to prevent damage to screens connections. hope this was helpful, good luck. Prodzilla
SOURCE: Sony Bravia 3D Smart Tv
If your TV is a month old call sony and get the TV serviced or exchanged. You are covered under warranty.
SOURCE: My Sony 3D Bravia Led tv turns on and than it
Call Sony and have the TV exchanged or repaired. you are covered under warranty.
