Cars & Trucks Logo
Claire Bass Posted on Apr 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireing diagram for 7 pin plugin trailer board lights
tjonesauto
Level 2:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Expert 69 Answers
  • Posted on Apr 11, 2017
tjonesauto
Expert
Level 2:
Filmmaker:
New Friend:
Answers
69
Questions
0
Helped
18601
Points
184
Steve Johnson
Level 1:
Habit-Forming:
New Friend:
  • Contributor 16 Answers
Steve Johnson
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
16
Questions
0
Helped
4090
Points
33
7-way RV Tow Vehicle Connector Wiring Color Code
# Color Gage Circuit Function
1 white 10 common ground
2 blue 12 electric brake
3 green 14 tail/running lights
4 black 10 battery charge (+)
5 red 14 left turn/stop
6 brown 14 right turn/stop
7 yellow 14 auxiliary/back up
NOTE: #7 is the center terminal and currently is most commonly used for backup lights.
7-way RV Travel Trailer Connector Wiring Color Code
2000 Dodge Durango. Wiring colors for installation of a 7 round trailer plug please?
Round 7-Pin Wiring Diagram
  • ? White Ground.
  • • Brown Taillights.
  • • Green Right turn / brakes.
  • • Red Auxiliary power.
  • • Yellow Left turn / brakes.
  • • Black Reverse lights.
  • • Blue Electric brakes.
Trailer Wiring Diagram and Installation Help - Towing 101
Need wireng diagram of 7 pin connector 221 model tnx
Trailers with electric brakes need them too. The 7-Way Trailer Plug is around 2? diameter connector that allows an additional pin for an auxiliary 12-volt power or backup lights.
https://www.ajtnt.com/Info/7-Way-Diagram
Connect to the brake controller and route the black and blue wires. Find the blue wire that comes off of your electronic brake controller. Attach the blue wire that came with your 7-wire plug to this blue wire. Locate the rubber grommet that surrounds the interior wiring harness where it feeds through the firewall.
https://itstillruns.com/wire-7pin-trailer-plug-4811994.html
Back of car has 7 wires to trailor plug but trailor has only 5 no blue or brown were for what blown fuses howerling help thanks jim
https://www.narva.com.au/resources/trailer-plug-wiring-diagram
make a 5 pin plug ---- trailer wire ---- 7 pin socket
converter cable
5 socket 7 pin round plug
Pin 2 to pin 1 left turn wire yellow
pin 3 to pin 3 Earth return to body of car
pin 5 to pin 4 right turn wire green
pin 6 to pin 6 brakes light red wire
pin 7 to pin 7 Tail light Brown wire
if it is a rectangular 7 pin then
5 socket 7 pin rectangular plug
refer to narva wiring diagrams to check
could use a 12v dc probe to sus out what the pins do.
might be able to buy a converter cable from a car spare parts shop maybe or make it yourself
1helpful
When I tow with my car the left blinker doesn't work on the trailer. There is a 7 pin round plug on the car, with a flat adapter to the flat pin on the trailer. I have had the same problem with at...
Hello Carol, The 7 way is for use with a brake controller and/or a trailer that has electric brakes. The 4 way flat is a basic trailer plug connector.
Connect as follows:
Green wire- Connects to the vehicles right turn wire harness & provides brake light and right turn signal on trailer.
Yellow wire- Connects to vehicles left turn wire & powers brake light & Left turn signal on trailer
White wire- Ground
Brown Wire- Tail/ marker/ license plate lights
The Blue, Red & Purple wires on the 7 way will not be used on the adapter, those are for brakes.
I hope this information is helpful.
10helpful
2answers
I need a wiring diagram for a 7 wire system
I am guessing you mean the 7 pin trailer tow adapter.
the 7 pin RV plug itself
The 2005 trailer tow adapter wire diagrams
3helpful
4answers
No trailer right turn signal or brake light
Hey Boon,
The pinouts for a 7-way plug are as follows:
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
In both cases 4 is battery and 7 is reverse, aux or not used.
Double check your wiring using these lists as a reference.
Click here for my post on Trailer wiring
This should get us closer to the answer.
Best regards,
Mike
Wiring diagram
If you are going from a 4 pin on your trailer to the 7 pin on the truck. You need to go to parts store or a department store (ex Wal Mart) and look in trailer section and find the adapter. Thats what I did. Also Remember if your lights don't work on trailer, check the plug to make sure its tight or check the fuse under your drivers side rear seat for that fuse box.
3answers
Wiring for a trailer
u must install the fuses for the system in he underhood heavy duty fuse box, it will be marked trailer tow
I need a wiring diagram for a 7 pin trailer board plug
Here's one
08-33-93f1.gif CAV CIRCUIT FUNCTION 1 Z13 12BK GROUND 2 B40 12LB TRAILER ELECTRIC BRAKE OUTPUT 3 L76 12BK/OR TAIL LIGHT (Trailer Tow Relay in PDC) 4 A6 12RD/TN* FUSED B(+) (40A, Always Hot, F8 in PDC) 5 L63 16DG/RD LEFT REAR TURN SIGNAL TRAILER TOW 6 L62 16BR/PK RIGHT REAR TURN SIGNAL CONNECTOR 7 L1 16VT/BK BACK-UP LAMP FIGURE 1: 7-Terminal Trailer Tow Connector
1helpful
Installing a 7-pin trailer towing recptical on a 1991 Ford F150.
I believe you can look up the manufacturer of the trailer plug kit and find the wiring diagram there. On alot of the trailer plug kits, they have pics and diagrams in the package. The 7 pin plug (truck side) is available with the pig tail set up that plugs directly into the wiring harness for the lights. Then all you would have to worry about is the 2 wires for the electric brakes.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
