Question about Planar Computers & Internet
Hi i have Planar PXL2430MW touch screen monitor display is great but i cant get the touch to work is something bad in it i searched online and there is nothing
SOURCE:
SOURCE: display problem
i have display problem some time show but some time not display
Posted on Jun 04, 2008
SOURCE: Monitor black screen with blinking amber/green light
You need to reset the display. The display is in a safe mode. Resetting the display is a simple procedure and Planar has the instructions on their website in their online customer support section.
Posted on Feb 26, 2009
skotkolr
  • 558 Answers
SOURCE: Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Posted on Mar 22, 2009
annual_uk1
  • 70 Answers
SOURCE: Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Posted on Aug 22, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a PE171 Planar monitor. goes black when turned on
Your monitor has 3 years warranty, I would find out if you can get the replacement before opening up the case.
http://www.planaronline.com/product/?id=997-2723-00
Posted on Feb 25, 2010
Hi,have a 60 inch plasma lg tv some 6yrs old or so and the picture has gone out but still have sound,any ideas?
screen out of works.
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 08, 2018 | LG Televison & Video
Characters as they are given in the challenge what do they mean by that.
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
Jul 06, 2017 | Televison & Video
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Monitor work but touch screen stop workig
the capacitor u changed might be the problem ... contact ur vendor for support
Mar 29, 2014 | Planar Pt1550mx-15" Blk Touch Screen
The touch screen does not work
here is the user's guide for your touch-screen monitor :
(from Planar's website)
http://www.planar.com/media/87916/mn-planar-pt1700-01-m-mu.pdf
Feb 26, 2014 | Planar PT1700M 17 in. Flat Panel LCD...
1. My printer displayed "USB Device Not
Jul 06, 2017 | HP Photosmart Premium C309A All-In-One...
Planar Monitor Wont stay on
Okay.... If you can. install your drive. It may work. If not then your Hardware in your monitor is screwed. Or maybe something else but not to my knowledge.
good luck!
Jul 14, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Planar 2010M auto adjust
This may be related to a power supply problem that these monitor have. I think you need to fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they have weird / intermittant problems.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company before you buy from them. I've seen a lot of complaints for this "international" company.
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors. (about $8 in new capacitors, plus shipping)
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technician for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
There is also a single capacitor on the display logic board, but I haven't seen this one go bad yet.
-Chip
Nov 22, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Computers & Internet Logo
185 people viewed this question
Top Planar Computers & Internet Experts
Thomas F. Schneider
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
