Showing depth and bottom contour but no temperature display.
SOURCE: Hummingbird Fishfinder model 535
The Depth & temp come from two different sensors. Check your coax cable to the transducer (the lager oval piece), the connector, and the transducer for cracks /breaks in insulation. Good luck.
SOURCE: Garmin Fishfinder 160 will not display bottom
Change your setting from saltwater to fresh water even if you fish in sea water,your transducer is a 00/200KHZ and not a 50/200KHZ.
Good luck
Willem
SOURCE: I have a humminbird pmax 170. It does not show
Contact our customer service group and they will be able to help you. There number is 800-633-1468.
SOURCE: I just bought a used
Check to make sure the transducer is hooked up correctly, and check the actual transducer for signs of damage. Transducers are fragile, and a good whack can break the crystal inside. For more troubleshooting, here is a helpful link with the Owners Manual for your Humminbird.
http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
SOURCE: The unit worked fine for 3-4 months.Now,it just
It sounds like your transducer has gone bad. You may be able to find a replacement on Craigslist or eBay, since this is an older model. Transducers are pretty sensitive to bumps and drops because of the crystal inside.
