There is no internal fuse that I am aware of, if it will not run then more then likely the control panel is defective.
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
SOURCE: LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
SOURCE: Bosch dishwasher SHE44CO2UC/22 no power or light
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
SOURCE: samsung HLS5686WX/XAA big screen has white dots,
Call Samsung! They do recall even if it's out of warranty.
They set a tech to come and fix it for free.
The Samsung DMR57LFS Dishwasher has a 15 Amp/250VP Volt Fuse located on the lower right side of dishwasher behind an aluminum panel held by two screws. Pull dishwasher out from counter, remove lower rectangular aluminum panel, and it is just inside underneath. Unscrew fuse holder and replace fuse. I had to pay a Samsung Authorized Repairman $109.70 to replace a simple fuse. I learned the hard & expensive way. Samsung won't tell you to check the fuse underneath the unit. They won't even tell you that there is a fuse underneath on the right side. The fuse protects the Printed Circuit Board or Blue LED Control Panel in the event of a power surge or lightning strike.The less than $4.00 fuse will blow first.
