SOURCE: How much roundup do I use in a gallon of water to get a good kill
This will be hard to answer because roundup is sold in different strengths. On a dry morning mix a few ounces of round up to a gallon of water and test it by spaying it on some blades of grass. Results should be noticed after a few days.If you spent allot of money for just a little roundup then you probably have a strong solution. Some roundup is already mixed with water (diluted) and can be applied as is. I hope this helps
SOURCE: Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
SOURCE: How to mix roundup to kill weeds
6 fluid ounces of Roundup (12 tablespoons) per gallon of water.
SOURCE: Danger of roundup applications around tree and bush plantings
Hi , I would be very carefull around good plants. Roundup will kill almost any plant, including aquatic plants, so you want to be sure to avoid spray drift onto other plants or into water.
