Question about Canon PIXMA MP530 All-In-One InkJet Printer
I assembled Canon mp530 sheet feed uniy but it does not work. What should I do?
4 Suggested Answers
SOURCE:
yooperbud
  • 8637 Answers
SOURCE: Canon MP530 ADF
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
venexcsd
  • 1185 Answers
SOURCE: Loose screw jamming paper in Canon Pixma MP530 printer
Go buy a magnetic retriever from your local hardware shop they are very cheap.
Make sure you get a slim version
Either that or turn the printer upside down and get someone to whack it on the bottom with the palm of their hand as you hold it
What goes in must come out
Posted on Jul 06, 2009
micromatikal
  • 2777 Answers
SOURCE: With my canon mp530 the paper will not feed into
Does it make the sounds as if it is trying to grab a sheet of paper and just will not? Try unplugging the printer from the power source for at least 2 minutes, then replugging it in. Try just a single sheet of paper in the paper tray. See if it will at least grab that.
Let me know what you find, just reply here!
Thanks
Tim
Posted on Oct 25, 2010
Canon MP530, would only print half of a page then quit and give me error message 5700. I would pull the paper out and shut down and would start and print only half of a page and stop. I would take out...
This error is referring to the ASF assy (Assembly frame which means the paper feed section)
This paper sheet feeder assy is a extremley complicated piece and is therefore not really repairable. You will need to take the machine to a canon repairer for a new assy sheet feeder to be fitted. It takes a trained engineer about 2-1/2 hours to fit one as the whole machine has to come apart and the new feeder has to be aligned while fitting. Its a job i always hate having to do. You dont have any other options i am afraid. Srri to bring you such bad news.
May 24, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
6A00 error code
Unfortunitly this isnt an easy fix. IF you still have it under warranty you can contact Canon and the ywill fix it. If its not under warranty they can refer you to the nearest Canon repair center.
- Sheet feed unit
- Logic board
- Purge unit
Best of luck..
Nov 22, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Duplex mode, paper retracted and DISAPPEARED!
For duplex the paper feeds into the bottom paper tray, you need to make sure that paper is not stuck in the bottom area.
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Jul 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Jul 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Display Shows Error 6A00 and it Doesnt Work ahead
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Jun 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 ADF
Jan 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Paperfeed snatches the paper
It is usually the same with most ADF's if you put in a single sheet.
Oct 18, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
