Question about Symphonic Televison & Video
Trying to connect streamsmart to older symphonic tv. Picture on screen rapidly jumping up and down. Can't program it. How do I make it stop?
LINES ACROSS TV AND PICTURE JUMPS UP AND DOWN HOW TO FIX
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 05, 2014 | Televison & Video
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
I have a symphonic flat screen tv. i am trying to connect it to a comcast cable box. i keep getting a message... protected program by TV-G. what does that mean and how do i get it off the screen.
Check the set by any other cable connection or use any AV input if you receive proper picture than your TV set is o.k,problem is with cable box,contact cable service provider to solve the problem.Also check by simply removing cable box the message will disappear.
Jan 31, 2011 | Symphonic Televison & Video
Trying to connect a Sega Genesis. I know it's connected properly to the place where the cable wire goes and then that is connected to the connector. What channel do I go to to play the games?
The input from the Sega wont be on any channel number - you need to select the correct input for the Sega using the "INPUT SELECT" button on the Symphonic remote control supplied with the TV. Switch on the TV the Sega, then press this button repeatedly until you can see the picture from the Sega.
- If you are using the sockets on the BACK of the TV, the correct input is "VIDEO 1"
- If you are using the sockets on the FRONT of the TV, the correct input is "VIDEO 2". You can also switch to the "VIDEO 2" input by pressing the "GAME" button on the Symphonic remote - if you still have it.
If you don't have the Symphonic remote, look for a button marked "INPUT" or "SOURCE" if you are using a universal remote.
If you don't have any remote for the TV, you will only be able to use the sockets on the front of the TV. You will then need to switch to "GAME MODE" by using the buttons on the front of the TV:
1. Switch ON the TV and the Sega;
2. Press the MENU button;
3. Press the VOLUME UP button to open the PICTURE MENU;
4. Highlight GAME MODE using the CHANNEL UP/DOWN buttons;
5. Set GAME MODE to "ON" using the VOLUME UP/DOWN buttons;
6. Press MENU again to close the menu
You should now be able to see the picture from the Sega. If not, check you have correctly connected the Sega to the TV. When you have finished using the Sega you will need to use the method above to switch game mode off again.
Hopefully, I've covered every possible angle. If you have a different Symphonic TV model from the one listed above (ST420FF), the method should be similar, but if you have any difficulty, please post back for further assistance.
BElectric.
Jan 16, 2011 | Symphonic ST420FF 20" TV
My tv won't play my DVD player. I don't have the original remote, but it is programed to a universal remote. Whenever I press the "TV/VCR" button all kinds of numbers pop up on the screen and the tv...
Your TV is responding as if the Game button was pressed on the original remote. The additional stuff on the screen is to let you set the best brightness and other settings for video gaming. These screens should disappear on their own in 10 seconds if no buttons are pressed on the remote. See the manual http://www.symphonic.us/support/manuals.aspx and fill in the model number. If the remote were still controlling the TV, the CH up and down buttons would let you choose the Picture settings to change and volume up and down buttons would change the setting.
The TV/VCR button on the universal remote may be swapping the remote to control the VCR only. (Thus losing the ability to control the TV.) (What does the manual say about the button for the universal remote?) You may want to consider a different universal remote - programmable or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=ST419E&uuid=12844254442790 which has an exact substitute.
Check your cables for the sound issue (try new ones) and make sure that they are fully seated in the jacks.
I hope this helps.
Sep 14, 2010 | Symphonic ST419E TV
A friend gave ne an old Symphonic TV with its Remote control. Trying to program my TV but the remote has the ''UP'' , ''DOWN'' , ''LEFT'', ''RIGHT'' arrows but NOT a ''SELECT'' button. I do I lock-in the...
u can go 2 buy a universal remote with a handbook 2 tell u how 2 program it lol.b alot easier.that way if u have dvd & vcr...it can b programmed 2 operate it as well as the tv!universal remotes r the best sollution lol.lazier the better lol.
Sep 23, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Programming the ramote to tv
i dont know how to program the remote for tv..i got the codes
Feb 28, 2009 | Philips Magnavox Learning Universal Remote
Channel scanning fails to stop at 3.
is there an auto scan option? if so turn it off and do it manually using the up down buttons
Jan 01, 2009 | Symphonic SC3813 13 in. TV/VCR Combo
Symphonic
if line is across screen thats virtical circuit prob. need tech or up and down horiz circuit. need tech
Nov 27, 2008 | Symphonic ST419E TV
TV will not work with good remote.
Sounds like the IR pickup has gone bad or the supply voltages feeding it are opened. Sometimes cleaning the screen with windex it tends to drip inside as it follows the picture tube down into the set . Most of the time replacing the IR cures your problem. Good luck
Mar 01, 2008 | Symphonic ST420FF 20" TV
Televison & Video Logo
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
