SOURCE: Unable to open yahoo email : error message code 2
Hi Tech support,
I am unable to open yahoo mail from last couple of days. It gives an error message after logging in and no emails open.
pls help me
SOURCE: icon has disappeared and error says printer spooler not running
This is because your spooler service has stopped on the PC.
If you have Win XP, click on start and click on Run.
Type services.msc and click Ok.
From the list, scroll down to Print Spooler.
Right click on this and click on Start or Restart.
Check if you have icon back or not.
SOURCE: Can not open Gigabank 8gb in windows xp
Read this article but only the Response section from
the site-reader:
http://www.hackphoto.com/2006/01/21/io-magic-gigabank-8gb/
Wow, you have purchased a "magical" device
that judging from the response from other owners like
you, its a disappointing investment :)
When you decide to crack it open and take the CompactFlash card to your card reader, you should aware
that you will suffer greater risks of damaging it, okay?
I have warned you :)
SOURCE: HTC messaging disappeared
I had this problem ,also no notifications of voicemail as well as not being able to acces the messaging screen. I was just about to send the handset in for repair and decided to remove the 4gb micro sd card .turned the phone off ,removed the card,turned it on again ,bam messaging works again !! hope this can help someone else too :-)
SOURCE: hi, i have just reinstalled Windows Xp
Right click on 'My Computer' and choose manage, then select device manager from the options that appear on left, all the items listed with yellow exclamation marks will need drivers before the devices will operate, you can get them here:-
http://www.pc-ap.fujitsu.com/support/drv_lb_wxp_s7010.html
