Question about HTC Computers & Internet
I'm trying to power up my HTC 510 after it quit on me. I've tried just about everything including buying a new charger and battery, but to no avail
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
Why won't my Pride Go-Go Elite Traveller batteries charge using a trickle charger? The batteries are new, but my charger quit working.
Hi Robert , can you clarify what you mean by a trickle charger ?, any chance of a photo of the charger ?
using a standard gel battery charger , the charger will charge the batteries in question and once fully charged, the charger will trickle charge the batteries.. This is a standard operation and recommended by battery makers...
Regards
Rob
Jan 09, 2016 | Pride Health & Beauty
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
HTC Hero won't charge. I bought a new battery...still won't charge. I've tried a wall charger and a car charger and neither of them work.
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Sep 01, 2011 | HTC Hero Smartphone
I am noticing a spot on photographs taken by olympus E-510
I'm guessing dust on the sensor. Google SLR sensor cleaning and you'll get full instructions on how to proceed. It's not difficult but you'll need to buy a few supplies.
Sep 25, 2009 | Olympus E-510 + 14-42 mm 1:3.5-5.6 Lens +...
HTC S710 - Battery issue
Hi guys
if u buy new battery for around 35$... its creepy thing that it again sucks within
6 month
so follow these procedure that i really got good response
1)Buy the new battery from any other dealers (u can use Nokia (std) or LG, Micromax, Onida... etc)
having same specifications as 1050mAh Lion-POLYMER 3.7v and having equivalent Size that fit into the case.
2)Now open ur dead battery, remove the sticker slowly, u wil get the polythene bag carrying the charge sheets
3)Please note that dont not disturb this polythene bag... (cutting, drilling or pinning), else it starts burning.
4)U will see a circuit above the polyhthene bag having two poles (+ve n -ve) just cut the poles of bag from the circuit and keep the bag aside
5)Now do the same procedure with new batt and remove the polythene bag.. and soilder with
the dead battery circuit. (check the +ve n -ve by multimeter)
5)Re-assemble with insulation tape and recondition it perfectly.
now check poles bofore starting.
Note : i got good result from this and i m getting 18-19hrs standby and 11-15hrs usage. Do it on ur own risk...and i m not responsable for ny harm)
Jun 02, 2009 | HTC S710 Smartphone
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
Computers & Internet Logo
24 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
