Gaggia Syncrony Espresso Machine Logo
Posted on Jul 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello. grinder won't grind
Hello.
i tried to change the grind level, while the grinder was running, as described in the manual.
suddenly the grinder started making noise like it's running without beans and a message appeard saing that there are no coffee beans in the macine.
now the grinder just bounces the beans and not grinding, and the message appears every time.
Philip Beanland
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 15, 2013
Philip Beanland
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
602
Points
I tried this on my machine and it worked. Remove power. Take everything out of the machine that would fall out if turned upside down. (water, extra beans, waste..etc) Then carefully pick up the machine and give it a good shake, may need to do that a couple of times. Hopefully you will dislodge the obstruction.
Anonymous
Level 3:
  • Master 1,089 Answers
  • Posted on Jul 24, 2009
Anonymous
Master
Level 3:
Answers
1089
Questions
0
Helped
521165
Points
4348
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
  • Anonymous Jul 24, 2009
    Hi
    Sorry but you don't have 2 knobs, so change the lever to a higher number than you had before the trouble. Grinds will get too fine or oily and stick together to cause the blockage.
My Jura Impresssa C5 grind motor stopping short?
Question edited for clarity.
Question moved from Misc category.
• The grinder can be set during grinding to grind approximately between 5 and 9 seconds, producing a milder or stronger coffee beverage (see chapter 9b)
Page 13
https://www.seattlecoffeegear.com/assets/user-manuals/jura/jura-impressa-c5-user-manual.pdf
Bunn g3 commercial grinder
Humm, G-3 grinders. Okay what common problems I've come across:
* Wrong setting for grind on label. Usually means worn out grinder burrs. But this does not happen often unless you are using it to grind commercial amounts of coffee? It's a retail level grinder meant to be user friendly and simple to use. Say grind a bag of beans once every 10 mins or so even with customers lined up to grind there own. Running a G-3 constantly is usually done by upcoming coffee vendors whom are using it for small flavored bean batches. But expect the burr plates to only last 3 to 6 months. We used to change it every month till the boss bought a bigger pro grinder. (whew!)
* Out of calibration (for grind) This usually happens as soon as it's installed. Either the grinder got banged (Dropped?) around or the lock nut was not tighten down. If caught quickly then it's a simple adjustment. Left unchecked will wear out the burrs or crack the plate.
* Trips out breaker. This is common at retail stores as it's located in a shelf rack that really does not have the required outlets. Many times there is a brewer(s) connected to the same line. It only trips out when one or both brewers are heating and the grinder is running a very fine grind.
* Trips out breaker when grinding espresso or very fine grinds. Worn burrs or slim chance the grinder was miss calibrated (but you would catch this when first installed)
* Shocks the customer. Dry climates or heavy air conditioning will build up static electricity at the chute. There usually a small chain attached to the chute to prevent this. Attach a SHORT metal chain or thin cable to the metal case of the grinder and add a metal clip to attach to the coffee bag. Many use a chain and clip just short enough to keep the bag positioned under the chute. Note many coffee bags come with bag clips. Just make sure the clip and chain can't get stuck in the grinder.
* Not working. This is usually the on/off switch as it gets beat up the most. There is sometimes a safety micro switch under the chute to sense if there is a bag there. I've found may have been defeated.
* No power, check cord, breaker (GFRI) outlet, Plug prongs if broken off or bent.
* power but no motor hum. Tripped thermal breaker (usually a red button on side or back. Some models may have it inside on the motor itself. Call for service to check.
* Turns on but loud hum (may be hot too). Burrs stuck. This could be from adjusting grinder while grinding beans and adjusting to a fine setting. Grinding finer slows down the beans feeding the burrs. Large settings flood the burrs with a lot of beans. Adjustments are usually done when the grinder hopper is completely empty. If loaded and turned down from coarse to fine grind the beans already in the burrs get crushed and stuck between the plates thus locking them in. It may be possible to clear the hopper and open up the grinder to its coarsest setting to jog out the crushed beans. Otherwise call for service to have the burrs cleared manually.
*Finally check with your vendor if your still having problems.
Aloha! ukeboy57
Grind time is short, puck is wet and sloppy, espresso weak
Sounds like you might have more than one problem.
From page 12 of the manual... NOTE THE LAST LINE.
"8. ADJUSTING THE GRINDER
• Open the lid of the bean container.
• While the grinder is running turn the grind selector switch to
the desired position (Fig. 6).
-The smaller the dots, the finer the grind.
-The bigger the dots, the coarser the grind.
Important:
The grinding grade can only be adjusted while
the grinder is actually grinding."
2helpful
2answers
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( http://kitchen.manualsonline.com/manuals/mfg/breville/breville_coffeemaker_product_list.html) they say wet coffee grind after extraction is normal.
But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
Good luck,
JF
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Saeco: grinder stops grinding
Hello, This may be the solution for you: having removed the ceramic grinder to clean out the unit, one of the wires on the grinder had become removed (the "center wire") on the connector. The 2 outside wires were sufficient to give me the illusion that the grinder was connected correctly, however it would only run for a half second and then coast to an annoying stop.
Check all 3 wires that connect to the grinder and make sure they are making contact.
Does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
Top Gaggia Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
