Televison & Video Logo
Pauline Newman Posted on Apr 08, 2017
Codes for a NEC tv using a Kmart Jumbo Universal remote control, factory no FOO3155 please
********* universal rdmote control, & nec tv, code has 4 numbers. Thanks
User manual for Kmart jumbo universal remote control Factory model FOO3155
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
2helpful
I digital universal remote RM-810 - need code for
Try 184 for the NEC TV.
Please rate this solution. Thanks.
2helpful
1helpful
I have an old nec croma vision tv and have lost the remote.I have a spare panasonic remote and want to no the code so i can use the remote with the tv
The remote for Panasonic TV cannot be used to control your NEC TV. For this you need a programmable remote control.
For example visit this site to know more about Universal Remote control. The UniversalRemote can be programmed to control TV, DVD etc. The procedure is givenin the accompanying manual.
If you do not want to invest in a universal remote then visit this site to purchase an NEC replacement remote.
Please try to understand that you cannot simply use any brand of remote to control any other brand of TV; only a universal remote (or a replacement) will help.
Thank you.
2helpful
2answers
Lost remote need code for universal remote control.
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your NEC from the list which follows:
    030, 056, 019
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
13helpful
4answers
Bigmatters universal jumbo remote ero4307j
manual de codigos del control bigmatters jumbo universal mod ero4307j
Top NEC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
