The part that goes in the laptop, not the plug to wall
You probably don't have to replace the part. On most Acer laptops, the DC power jack attaches to the mainboard with a cable. The power jack is usually held in place by a plastic bracket inside the laptop. This bracket is probably broken. Here's what I would do:
Open the laptop and find the bracket that holds the jack in place. It is probably broken, and you may have pieces of plastic rattling around. Find the plastic pieces and superglue them back in place, put the jack back into position and reinforce the back of it with a bit of hot glue. I have done this dozens of times in my repair shop. If this is not the problem, or you are not confident in doing this then take it to a reputable computer repair shop :)
Hope this helps!
Joe
SOURCE: Dell Latitude D430 laptop. Laptop
the issue seems with the inverter board of the machine and chek once the machine at any other place.
SOURCE: Acer 5920-6474 does not power on
the problem lies with failed smd capacitors grounding out underneath the motherboard on the same side of the board as the cpu heatsink. if you look at the board with the heatsink/fan in the top right hand corner- the culprit caps are in the bottom right hand region under some see through plastic. they are labeled pc144 and pc145.
SOURCE: My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
SOURCE: Acer Aspire 5920-6864 Is not turned on
this probleme is common among acer 5920, the probleme is with the motherboard that's of bad quality and workmanship. Acer should be ashamed to sell a PC with a faulty motherboard and should compensate all 5920's owners or replace with a better motherboard. 1000's if not millions are having the same probleme wich tell to anyone with a brain that Acer 5920 is a scam. good luck. x
SOURCE: LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Testimonial: "Thanks! I removed the battery and it started right up! So would a new battery fix it? The only thing is the touch pad is not working. We plugged in a "
