My fire stick remote won't navigate all directions and keeps telling that the remote is "not clickable" . Had same issue using fire stick remote application on my phone.
To disconnect your Fire Stick remote from your TV, you can follow these steps:
1. On the home screen of your Fire Stick, go to "Settings" in the top menu bar. 2. Navigate to "Controllers & Bluetooth Devices" and select "Amazon Fire TV Remotes." 3. Select the remote you want to disconnect and then choose "Remove." 4. Follow the on-screen prompts to complete the removal process.
To reconnect your Fire Stick remote to your TV, you can follow these steps:
1. Turn on your TV and make sure that it is set to the correct input for the Fire Stick. 2. Press and hold the home button on your Fire Stick remote for at least five seconds. 3. Wait for the remote to pair with your Fire Stick. Once the pairing is complete, you should see a message on the TV screen confirming the connection.
If you want to disconnect and reconnect your Fire Stick to your Element TV, you can follow these steps:
1. Unplug the Fire Stick from your TV's HDMI port and power source. 2. Wait for a few seconds and then plug the Fire Stick back into the HDMI port and power source. 3. Turn on your TV and switch to the correct input for the Fire Stick. 4. Follow the on-screen prompts to complete the setup process.
Once the setup is complete, you should be able to use your Fire Stick and remote as normal.
please update your tv's firmware/software. If this does not solve the problem, you might need to update your physical firestick (ie get a newer replacement).
Pair Firestick remote to TV
Go to Settings on your Fire TV. Select Controllers & Bluetooth Devices. Select Amazon Fire TV Remotes. Press and hold the Home button for 10 seconds to pair your remote.
Hold down the Select button for 5 seconds to put theremote into pair mode. Hold down the Select + Play buttons together for 5 seconds to Restart the device. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. firestick remote won work Google Search
hi there.
this is all i can find out. How do I fix my Firestick?
Hold down the Select + Play buttons together for 5 seconds to Restart the device. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. problem with the Amazon Fire Stick and the remote.30 Sep 2015
hi Paula.
not sure if this will help you out. To restart your Fire TV: Unplug the power adapter for three seconds, then plug it back in. You can also restart your device with your remote. Press and hold the Select and Play/Pause buttons at the same for about five seconds, until your device restarts.
https://www.amazon.co.uk/gp/help/customer/display.html?nodeId=202104870
Why does my fire stick not turn on?Restarting your device can resolve many issues-just disconnect the power cord (from the back of the device or from the power outlet), and then plug it back in. You can also use your remote to restart your device. Press and hold the Select and Play/Pause buttons at the same time, for about five seconds.Amazon.com Help: Basic Troubleshooting for Fire TVhttps://www.amazon.com/gp/help/customer/display.html?nodeId=202104850
if this does not help you.go to this link and see if its of any help to you. fire stick is not connecting to internet Google Search
Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. Press the Menu + Left (directional key) + Back buttons at once for 10 seconds. These are the steps for factory resetting of remote.
There is no capability to use a fire stick on a laptop. Even those with HDMI ports won' support it since laptop HDMI ports are output only.
Anything you can access with the fire stick you can already access online, so you really don't need the stick. Here is a forum discussion thread on the issue. Hope it helps!
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
