You are going to have to register with Kohler and use this site to get your part:http://www.kohlerpower.com/residential/sectionfront.htm?sectionNumber=13561
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Check the oil pressure switch, and oil level first. Then check rotor brushes and rotor slip rings may need polishing. If the problem is still there check stator and rotor windings
try to find the manual , these units have a pre program set from the factory, dissconect the unit at the generator 1)battery terminal 2)main switch on generator 3) reconnect battery and turn on the switch,press auto,should reset
Although A bit inconvienent this does seem to be the norm for some Kohler units. Actually a small price to pay rather than having a technician come out to replace the ATS control board. There are time delays that could be set longer to keep the unit running longer and may prevent this from happenng
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
