Garden Logo
A
Aaron Dale Smith Posted on Apr 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If it takes 6 ounces to treat 21 gallons, how many ounces treats only 2 gallons? Is the answer 1/4 ounce???
I need to add fuel cleaner to my lawn mower motor, but the cleaner if for automobiles, 6 fluid ounce bottle for 21 gallon tank
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Garden Master 102,366 Answers
  • Posted on Apr 06, 2017
Garden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428578
Points
622693
4/7 ounces (about 0.57 ounces).
My Honda EU3000is only runs with the choke on. With the choke on it blows a little bit of smoke and somewhat surges. What is the issue?
Likely a fouled carburetor or water in the fuel bowl. Try draining all the fuel, see instructions in manual.
Take a clean dry fuel container to the gas station and get 1 gallon of fresh fuel. Add 1 ounce of Seafoam fuel treatment. Measure don't guess. Poor entire gallon into generator.
Start generator. If same problem, then carburetor is fouled and will need cleaning. You could try running with the treated fuel and it may clear the fouling. Otherwise a more thorough cleaning will be necessay.
Why does my la 110 stop running when I release the brakes or try to engage the mower deck
My Huskey 42" had that problem. I believe the motor bogs down too much, when mine tried to die, i'd choke it real fast and it'd catch back up, or just push in the clutch. But I'm pretty sure its a carburetor thing, probly needs cleaning. I put some fuel system cleaner in with gas, and it runs like brand new. Not stabilizer, Cleaner is whats needed. It comes in a 16 ounce bottle to treat 21 gallon tank (for auto) So in a 2 gallon gas can, mix almost 3/4 of just 1 ounce. Try that first
Apr 06, 2017 • Garden
1helpful
If a pond takes 3.5 chemical ounces to treat 1,000 gallons, then how many ounces to treat 570 gallons?
Take 1000 into 3.5 (3.5 divided by 1000) to get how much chemical is needed to treat one gallon. Then multiply that value by 570 to get what is needed for 570 gallons.
3.5 / 1000 = 0.0035 * 570 = 1.995 ounces to treat 570 gallons
2answers
Anyone know the fuel mix ratio for a Ryobi Supreme 720.
I have this machine and it states it requires 4 ounces to 1 gallon gas. This is if you use the i.d.c.oil which is 32:1 it states if other 2 cyc oil is used it requires 6 ounces to 1 gallon fuel. Im trying to add a picture of the machine. I have aryobi 720 sieries. The newer ryobi machines call for the 50:1.
Fuel mixture Z830sd Homelite trimmer
Since my research shows this to be an older unit, I recommend a 40:1 mix. That is 3.2 ounces of 2 stroke oil / gallon of gas, or 1.6 ounces of oil in half-a-gallon of gas. Here is a mixture chart.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
Sep 04, 2011 • Garden
2answers
How much oil would i ad to a pint of gas at a 50 to1 ratio
A pint is 16 ounces, add 1/3 ounce of oil for a 48:1 mixture.
Gary
Aug 30, 2011 • Vacuums
2helpful
2answers
Need to make 50:1 ratio mix. what i have on hand is the poulin 3.2 fluid ounce that makes 1 gallon at 40:1. how many ounces of this mix would need to be used to achieve the 50:1 mix ratio.
2 choices here
if you want to use the entire 3.2 oz bottle you need to add it to 1.25 gallons of fuel to = 50:1 ratio
if you have 1 gallon of fuel you need to add 2.6 oz of oil to the fuel to equal 50:1 ratio
hope that helps
How do I change one gallon of a 50:1 gasoline mixture to 40:1?
  • 40:1(gasoline:oil) ratio requires 3 ounces of oil.
  • 50:1(gasoline:oil) ratio requires 2.6 ounces of oil.
  • So for you to change to 40:1 you need to add .6 ounces of oil
    Apr 01, 2010 • Garden
    Top Garden Experts
    Jay Finke
    Jay Finke
    john h
