It's the cord that goes from the DVD player into the TV. I do hope you can help.
SOURCE: hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
SOURCE: portable dvd replacement charger
Anyone needing to replace parts for a Durabrand item, I located this website after many hours of research. They have a number of replacements parts and they aren't that expensive either. Good Luck
http://www.1800customersupport.com/products.aspx?cid=4
SOURCE: Can't find the parts I need
Hey, not sure if you still need it, but there's a power cord for the PDM-2727 listed in an Ebay auction. Like you, I need the AV cord, er, at least I think that's the problem. The listing also shows an AV cord available for an extra $5 but it looks generic. Might be compatible though. I don't need the power cord or I'd ask the seller, but you might want to check it out if you still haven't found power cord/AV cable yet.
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
SOURCE: connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
