Garden Logo
Eddie James Posted on Apr 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installed a new carburetor on stihl bg55 blower. primer bulb filling up but is not pushing gas into carb. no cracks in line filter is good. Have tried two new carbs with same result.
Steve Sweetleaf
Level 3:
  • Master 1,212 Answers
  • Posted on Apr 06, 2017
Steve Sweetleaf
Master
Level 3:
Answers
1212
Questions
5
Helped
433627
Points
3475
If the bulb wont prime you have a leak some where lines, tank, cap, if it is not air tight it will not pump.tank full of gas.
Stihl 55 Blower, runs for 5 mins then bogs down and stalls. I have replaced fuel filter, fuel lines, air filter, carburetor and spark arrestor. I checked exhaust for blockages, still has the problem?
It is a fuel / air problem. Do you have a primer bulb, did you replace it and put it in the right way around arrow to the carb? It is a known issue. There are lots of help online and there are some videos below..
I have a stihl model bg 55 blower it starts fine runs for 5 ...
JustAnswer https://www.justanswer.com > small-engine > 2otj1-sti...
Oct 22, 2009 - cub cadet self propelled mower starts up fine runs for about 5 min. then dies. Will start again after several pulls then dies again 4-5 min.
1 answer · Top answer: 3 real options. I will start with the easy one. 1. Your gas cap could be not venting correctly. ...
Stihl Blower BG55 Bogs Down - Arborist Site
arboristsite.com https://www.arboristsite.com > threads > stihl-blower-b...
Dec 5, 2013 - It I lock it on full run eventually it works itself out within 10-20 seconds. Since it never lasts long I have always put up with it, until now.
Stihl bg86 leaf blower bogs how to remove limiters?
Nov 16, 2015
stihl sh85 bogs down after start- how to fix. - Arborist Site
Sep 13, 2009
Stihl BG56C blower bogs when the throttle is engaged
Mar 28, 2020
More results from www.arboristsite.com
Blower: Runs For A While Then Dies
eReplacementParts.com https://www.ereplacementparts.com > lawn-equipment
If your blower runs for a while then dies, you'll need to check the fuel filters, spark plugs, and more. Our troubleshooting and repair guide can help.
Stihl BG55 Blower Problem!!! - Lawn Care Forum
lawnsite.com https://www.lawnsite.com > ... > ?? Mechanic and Repair
May 1, 2008 - After the first couple minutes of running, the blower will normally bog down briefly and then I let off the throttle. Once I reapply the ...
Missing: stalls ‎' Show results with: stalls
Stihl leaf blower- running problem
The Garage Journal https://www.garagejournal.com > forum > threads > sti...
Nov 12, 2009 - I have a BG 55 when fuel tank gets down to 1/2 empty it stalls out. ... run, it revs up to max then dies completely. It will only start on full ...
1helpful
I have replace the primer bulb on stihl blower BG55, still will not prime the machine, please help, when i push the bulb, I hear air squeal
Without having the unit in front of me to inspect it could be several things. Check any and all rubber fuel hoses to make sure they are not cracked. Since the bulb is a part of the carburetor it could be the fuel line coming out of the carburetor which could be loose or cracked. I would replace the entire carburetor since it is easy to replace and doesn't cost a lot of money.
Jul 05, 2016 • Stihl Bg 55
Both my Echo line trimmer and Stihl hand held blower. No fuel in the bulb on both, I suspect bad fuel. If so, how do I fix?
Check INSIDE the fuel tank. It is possible the fuel line inside the tank has deteriorated and the filter broke off. That would cause fuel line to FLOAT in the tank instead of lie on the bottom. This could easily be the cause of no fuel in primer/purge bulb. You probably need to:
Install new fuel filter..........Install new fuel Lines.......Install new primer bulb........Clean carburetor.
So in some respects, you are probably correct....no fuel filter equals bad fuel entering carb (but if none in bulb, doubtful much fuel (dried up maybe ) in carb.
2helpful
Gas lines crumbled and don't know how to route new lines correctly
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
No gas to carb
There should not be a vent hose--it probably goes to a port on the primer bulb. Check the fuel filter for plugging and the condition of all fuel lines (they should be original rubber, not plastic replacements). Try priming the carburetor with the bulb pump--it should pull fuel into the bulb after several pushes. If nothing, check the condition of the primer bulb--it should be soft without cracks or holes.The primer is supposed to pull fuel from the tank's fuel filter, into the carburetor top section, pass into the lower section through the metering valve which is controlled by the diaphragm, then out to the input port of the primer and out the other primer port to return fuel to the tank. Go to: http://www.drystacked.com for an excellent 12 page article on theory and troubleshooting of Walbro carburetors. Hope this helps!
3helpful
I have a Stihl BG55 Blower Gas comes out of muffler.
you have a piece of trash/debris under the inlet needle of the carb and or a welch plug has come out, ive seen this many times on zama carbs, if its within warranty bring it back to your service center for a new carburetor.
Nov 18, 2009 • Garden
1helpful
No gas when you prime it
1) Check fuel lines from tank for cracks, fuel filter in tank, primer bulb for cracks
2)Remove Carburetor
replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
1helpful
I have an echo C8 345 that will not run more than 5 secs. when you push the primer bulb and fill the carb, it will run until that is used up and quit. i took the fuel line off at the carb and gas runs out...
If pushing the bulb feeds fuel to the carburetor it isn't conneced properly.
EchoUSA
http://www.echo-usa.com/pdf/documentation/CS300_100605.pdf
  1. The filtered hose from the fuel tank connects directly to the carburetor input connection.
  2. The output line from the carburetor connects to the suction side of the primer bulb (once bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  3. The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 • Echo Garden
5helpful
Routing of fuel lines for a weedeater bv200 type 2. Which lines go where from the carb into the tank?
The line with the filter goes to the bottom of the carb. The other line goes to the outlet side of the primer bulb and the other line from the primer bulb goes to the top of the carb (The primer sucks gas through the carb).
Ps. if you are not sure which nipple of the primer is the outlet port then put your finger on one of the ports and push the bulb. If the bulb stays ridged then that's the outlet and if it collapses but doesn't fill but up then that's the inlet side.
Jul 10, 2009 • Garden
12helpful
3answers
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
