When I turn the printer on the green light comes on then goes to Yellow and will not print or turn off. tried unpluging the printer and turning it back on..same thing happens nothing.
SOURCE: CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
SOURCE: Problem with printing
Sorry the manual doesn't help much either... this is what it says, "POWER lamp flashes alternate green and orange Turn the printer off and unplug
the printer from the power supply. Plug the printer back in and turn the printer
back on. If the problem remains, contact
a Canon service representative."
You could try the following reset code which works when reseting after emptying the waste ink tank:
Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume
button go.
4. Press Resume button 2 times then let BOTH
buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume
button 4 times.
7. Press the Power button and the printer should
turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope it helps
SOURCE: Flashing lights and no printing
If the two lights are blinking persistently and the carriage is moving freely when the cover is opened then the logic board has problem and should be replaced. However, if there is some restriction of carriage movement or cracking noise, the optical cable should be replaced. Good luck
SOURCE: printer will not respond
Canon S330
Turn off printer
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
SOURCE: HP Deskjet 1220c Orange and Green light on
TRY LUBRICATING THE SILVER SLIDE BAR WITH SOME SEWING MACHINE OIL,DONT GET OIL ON ANY OTHER PARTS
