SOURCE: Ballpark price on 2007 Mercedes Benz C230 Maintenance B
The dealer near me charges $365 for a 4-cyl, $395 for a 6/8 cyl, or $425 for a 12-cyl. The only actual repair/maintenance you get for that price is an oil change (with Mobil1 and the MB filter, which are CRITICAL, ~$120 on its own) and tire rotation. This makes a lot of people think it's a scam, but really, it's a little steep, but definitely worth doing. The rest of the service consists of a massive inspection of your vehicle covering the following items.
-- Fluid levels
-- Tire tread/pressure/wheel condition
-- Air filter (inc. clean out housing)
-- Cabin air filter (inc. clean out housing)
-- Lubricate sunroof rails, locks, hinges, and seals on body.
-- Drive belt and tensioner
-- HVAC system operation
-- Instruments, cruise control
-- Wipers/washers/lights/horn
-- Windows/sunroof operation
-- Hoses
-- Transmission fluid
-- Brakes
-- Chassis/suspension
-- Driveshaft, inc. flex discs
-- Road test
-- Reset maintenance light
This is actually pretty essential to do, despite seeming like a lot of money for not much work. I have very rarely done one without catching a few things that the customer needs, and often it was a problem that would have gotten far worse had it been left to its own.
SOURCE: 2008 mercedes benz C-350
i believe that a dealer most do it...although if you call a certified dealer they might release you the info on how to do it..hope that helps
SOURCE: 1995 Mercedes Benz C220 will not start, and key
hello,steering lock mechanism and your key need to replaced,if you want try to remove your under dash,steering lock mechanism have a small pin(around 5 mm) which pit to steering housing,drill out the lock,then try to turn steering wheel,ty
SOURCE: warning light on mercedes benz 300e year 1989
A Mercedes benz dealer in parts and service should be able to order a manel for you if not,try Auto Zone they have the chelton books that show how to for Mercedes.
SOURCE: my mercedes benz c280 wont let me turn the key
you know that you have to put the car into park before you can pull the key,well.....its controlled by a switch on the gear linkage.
