I have downloaded maps for my garmin and they're saved in .IMG however after I copied them into my sd card and placed the card into my nuvi 350, I cannot seem to fidn them or else the nuvi cannot read them. Where do I access the sd card on nuvi? I've been to map info, however I can only see my previous maps. Do I need to use mapsource before actually placing them on the sd? can you help me out please. I shall be going abroad soon and I need them.
thanks
SOURCE: USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
SOURCE: Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
SOURCE: Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Try these two reset procedures
Procedure 1:
1)disconnect nuvi from external power
2)Flip up GPS antenna
3)Press the reset button
4)Connect nuvi to power source. The nuvi should turn back on and operate normally
procedure 2:
1)Hold your finger on the upper-right corner of the nuvi's screen while you turn it on. keep your finger until the pop-up window appears
2)Touch YES. All factory settings are restored. Your recent selections and audio bookmarks are also deleted
Are the maps within a folder named "Garmin" on the SD card? Also, the file name can not be "gmapprom.img" as it will conflict with the file on your unit... it has to be named "gmapsupp.img" and you need a "gmapsupp.unl" unlock file.
Map files on the SD card have to have a different file name as well as a different filename for the map unlock code. They also need to be in a directory called garmin on the SD card. The map file names on a Nuvi (internal directory) are gmapprom.img. The unlock code file is named gmapprom.unl. On the SD card the map files need to be called gmapsupp.img and the unlock code file is gmappsupp.unl. If all is correct, it should boot up looking at the SD card map files. - Jim SHARCNET-USA
