Refrigerators Logo
L
Luiz Alfredo Posted on Apr 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher and dryer Samsung WD0754W8EXSA. I can change the thermostat DC47-00016B for DC47-00016C, I appreciate your cooperation.
The DC47-00016C thermostat has stopped working. I bought a DC47-00016C part, but it was delivered the DC47-00016B. Can I put a DC47-00016B in place of the DC47-00016C? (in Samsung WD0754W8EXSA)
John Tripp
Level 3:
  • Samsung Master 4,656 Answers
  • Posted on Apr 04, 2017
John Tripp
Samsung Master
Level 3:
Answers
4656
Questions
Helped
1679102
Points
14883
That part is most likely the same thing just a new part number.
2answers
Why is my Samsung DV 350AGP XAA stuck in cool down mode
The issue may be caused by a faulty thermistor. The thermistor is responsible for monitoring the temperature of the dryer. If it is malfunctioning, the dryer will stay in cool down mode as it cannot determine that the temperature is within safe levels. Check the thermistor connection and if necessary replace it. If this does not resolve the issue, you may need to contact a professional repair specialist to further diagnose the fault.
Dishwasher and dryer Samsung WD0754W8EXSA Well to change the thermostat DC47-00016C by DC47-00016B? I appreciate your cooperation.
This is a thermal cut-out device, rather than a thermostat. A thermostat regulates temperature while a TCO is an emergency cut-out, similar to a fuse but activating at high temperature. Specifications are as follows:
Samsung DC47-00016C THERMOSTAT, 125/250V,16A,-35,125+-5.0
Samsung DC47-00016B THERMOSTAT, 125/250V,25A,-35,125+-5.0
So from the data, your part DC47-00016C is rated at 16A max current while the DC47-00016B is 25A. It is therefore acceptable to use the DC47-00016B with a higher current rating.
The Thermal cut-out device is rated at 125+/- 5.0, so will activate at temperatures from 120 Celsius. You should investigate why the TCO activated otherwise you could have the replacement do the same thing.
3answers
Dryer spns but there is no heat
probally the heeting element
1helpful
What causes a thermal fuse to burn out on a samsung front load dryer
Lint exit tubing may be clogged. Need to clean periodically.
My samsung DV219AG Dryer recently not working properly, has low dryer temperature, unable to dry clothes.
CLEAN FILTER OR CHANGE TEMPERATURE SETTINGS. IT COULD BE FOULTY THERMOSTAT OR HITING ELEMENT
4helpful
Where is the thermostat on 2002 mini locted. blocked need changing.
the thermostat is located in the cylinder head and is retained by a plastic housing (aluminum on COOPER S). the thermostat begins to open at 89-92°C and is fully open at 103°C.
the MINI COOPER thermostat housing also incorporates the cooling system pressure cap (MINI COOPER S system pressure cap is installed on the expansion tank).
need remove intake filter housing an map connectors
1helpful
2answers
Where on the engine is the thermostat. I have a 2007 mini cooper s R56
Find the hose that goes from the radiator to the motor and detach the motor end, The thermostat will be inside there.
2006 mini cooper s heat not working
your heater core may not be working as it could be clogged,located close to the gas pedal hidden behind a small plastic cover
Samsung dryer blowing thermostats, constantly
you may need to replace both thermal fuses and or the heating element itself but check to make sure you have the proper temp rating for the thermal fuses
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
