Approximately 5 years if no problem arises on power source and devices connected with it. Usually if the power does not come on you have to check fuse inside the power supply. It might got a power glits
The PUK code is unique to your SIM card, so you can only get this from your mobile network. Sometimes they will give you this when you first get the SIM card, but not all networks do this. If you cannot find it, give your mobile network a call and they will be able to give you the PUK code after you have answered some security questions.
To make things a bit easier for you, here are the contact details for most major networks:
Do you feel heat on both heater core hoses? If not then it might have a blocked heater core, low coolant level, defective heater control valve or a blend door issue.
GET A SCHEMATIC OF 02 SENSOR CIRCUIT. IN MOST CASES YOU WILL HAVE 4 WIRE. 1= 12V FOR HEATER 2= GROUND FOR HEATER 3=REF VOLTAGE FOR SENSOR 4=SIGNAL RETURN TO PCM
you are getting this message, because it has viruses. You can open this by selecting inernet explorer from the menu or Open my computer and go to address bar and select CD Drive from the drop down menu. it will open. use a usb harddisk or flash drive to take the back up of your system.
Copy and paste the link below on your browser address bar (eg. on Internet Explorer):
http://www.volvoclub.org.uk/faq/EngineSensors.html#OxygenSensorLifeandDiagnostics
Normal 0
Worth a try: I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print buttonapplying a slight amount of pressure on the Card Stock so it will feed throughthe printer. The reason for this, in some cases I have been able to clearthe paper track of debris that was deposited there over time. Worth atry. I have fixed a number of printers this way saving costlyrepairs. Bud
