SOURCE: How To Adjust Idle For 1992 Mercury Grand Marquis
there should be a screw on the throttle body, if there is not replace throttle position sensor or the idle air control motor.
SOURCE: 2003 mercury sable, not idleing right
I was looking under the hood, and noticed that i could hear air rushing around. I found that a vacum hose had decayed and cracked. After i replaced that, everything has been fine
SOURCE: mercury mountineer running fine then started running rough
pulls codes first auto zone checks for free
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
