Question about Leisure Pool & Spa
My heater won't come on , on my garden leisure spa, it says cooling to 80
    Top Expert:
  • Leisure Master
  • 10,025 Answers
Either temp sensor or heating element
Posted on Sep 13, 2017
4 Suggested Answers
SOURCE:
  • 990 Answers
SOURCE: Spa Heater
You need to check your temp sensor and your high limit. Both are tubes that slide into the plumbing on or near your heater. If this is a tube heater then they are probally at on each end of the heater and will have small wires coming from them that go back to the control board. Farely common problem and easy enough to fix with replaceing them both. A number of models wire them together so they come as one part. Good luck.
Posted on Jan 20, 2010
james3751
  • 614 Answers
SOURCE: replaced heater failed within 2 months
If your filter is plugged causes the heater to work harder(overheat). Rus
Posted on Mar 17, 2010
uspartscente
  • 719 Answers
SOURCE: leisure bay spa series c,
What light is blinking? The heater light? Because the heater light will not come on until the spa goes through the purge cycle when the breaker is first turned on.Exactly what is happening once the breaker is turned on
Posted on Feb 11, 2011
I just bought a used older garden leisure spa, it won;t turn off. The manual says push button once for low pump, twice for high pump and a third time for off. I only get low and high pump speeds.
This can be normal depending in the settings. It may continue to run for upto 15 minutes, its just looking to satisfy it's heat or filter cycle.
Dec 14, 2016 | Pool & Spa
Circutboard trace break for garden leisure hot tub
check the timer and thermostat settings also the heater contacts see if they need cleaned(shut off or unplug before servicing..severe shock hazard!!!)
Dec 14, 2013 | Pool & Spa
Garden leisure spa
check to make sure you are getting 220 to it if not the check breacker
Sep 07, 2013 | Pool & Spa
Pool & Spa Logo
178 people viewed this question
Top Leisure Pool & Spa Experts
Kardoc
 steve
steve
Steve Slater
Are you a Leisure Pool and Spa Expert? Answer questions, earn points and help others
