Well I know for sure the default pin for the M1 is indeed 0000. However I
cannot tell you what the pin would be for your specific bluetooth
dongle. If I where you I would try 0000, 1111, 2222 and so on
As with all Bluetooth headsets,
the H700 needs to be paired with the device before it can be used, which
is done in pairing mode. In pairing mode, the H700 makes a transmission
so that Bluetooth-enabled devices can pick up the device and connect to
the headset. Once connected, no other device can connect with the
Bluetooth headset. To enter pairing mode on the H700, open the headset
boom located near the microphone. After a few seconds the indicator
light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
Once the H700 is in pairing
mode, have the M1 search for Bluetooth devices. To do this, press
"MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A
list of Bluetooth devices will show up on the screen. Highlight
"Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter
"0000" and press "MENU/OK." The devices are now connected and ready to
be tested.
Testing the Devices
Once the devices are connected,
test that both the phone and the headset are working properly together.
First, place the headset in your ear. Dial a number on the phone and
press "Send." If you can hear ringing, the devices are connected
properly and ready for use.
If the connection was not successful, repeat the previous steps and
try again. Make sure the indicator light is glowing purple and is
steady. If you have connected the headset to a previous device, make
sure that device is turned off so as not to interfere with the
connection procedure. Once the other device is off, close and reopen the
boom to enter pairing mode.
Check with Sanyo. You typically have to enter on your phone the code from the other Bluetooth device. Never heard of a TV having Bluetooth. What model TV is it?
be tested.
Testing the Devices
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
