I just got this car recently and it has been through a few snow and rain storms. However the other night it rained hard and I came home from work the next day and was going to go for a cruise but found my floor carpet to be soaked. I looked all around and everywhere else is dry; the sunroof, all around under the steering wheel, etc. The only water I found was drops dripping downwards from the plastic beside the door on the side of the dash. I couldn't see any farther up than about the height of the hood as the side of car turned to metal. Any ideas?
I had this problem once with mini-van that I owned and it turned out that the grill on the outside, at the base of the windshield had plugged with tree debris and the water could not find the drain hole so it backed up and came in under the dash and filled the cavity where the blower motor for the heater sits.
I cleaned that out, pulled the blower motor and dried the tub it sat in which by then had mildewed, then put it all back together and things were fine. The blower motor had shorted out by the way so I had the fun of buying and installing a new one.
SOURCE: water on the passenger side floor when it rains
Sounds like the drain for your heater case is blocked, there is a small drain tube on the engine side of the firewall on the passenger side, you can shine a light down there and poke a screw diver in it or just pull the elbow right off and it should take care of it.
SOURCE: Water leaking into 2005 Camry 6 cyl under carpet drivers side.
I think that I can help you. It sounds like your drain-tube is plugged up. Get in the passenger side, and pull the carpet back from under the glove box. Look for a black rubber pipe that goes from a black box, and pokes thru the firewall, on the passenger side. Remove the hose from the box, and have a container ready to catch water. If water comes out of the black box, your drain hose is plugged up. Clean out the clog, and you will be golden.
SOURCE: Left back floor was soaked after driving in heavy rain.
IS THIS CAR FOUR DOOR OR TWO NEE D TO NO SO I CAN TELL YOU WITCH WAY TO GO ANY WAY I WOULD GET A HOUSE OUT BUT SOME ONE IN CAR IN BACK AREA AND SEE IF THEY CAN FIND LEAK IT MAY BE AROUND WINDOW SEAL HOPE THIS HELPS SEEN THE SEEM IN WHEEL WELL DO THIS BUT MAY BE BACK WINDOW SEAL IS TRUNCK WET TOO .
Testimonial: "Sounds worth a try. Car is 4 door. Thanks, Jean"
SOURCE: I can hear water sloshing
The water probably went down between the window and the door. On the bottom of the door is a drain hole, with all that rain it looks like the water in the door washed some dirt or something over the hole and stopped it up but not before it went inside the car and onto the carpet. Just unplug the hole with a small stick or something and watch for the water drain out. Open the doors and let your car dry out. Should be O.K.
SOURCE: Sunroof leaks. Every time it rains the sunroof
Never need a dealer for any auto repairs ,why do you think ,there are 200,000 repair shops on every corner?
The roof drain hose may have come off
Loosen headliner and check out
