SOURCE: LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
SOURCE: water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
SOURCE: F02 error code on Fagor FU6146IT
attempted to look up your washing machine on www.repairclinic.com they don't list Fagor, but you can go to that site and do some research. That website lists error codes for countless appliances as well as troubleshooting guides for the codes. Good luck
SOURCE: soap doesn't dispense
There are different tips, In order for the unit to siphon the soap you need to use the tip that is for detergent. Its basically a tip that does not produce a high pressure it's more or less a soaker. Unit won't siphon under pressure. I hope this answer your question please rate the answer if it was helpful. Good Luck and have a great day. Jeff
