SOURCE: X-box 360 controller will not switch on
Sometimes you have to beware of unknown batteries, because some companies that make the batteries are fake... However, look below for some of my FAQs (Frequently Asked Questions)
1. My battery pack won't does not work, and/or it will not turn on...
First, make sure that you have the right batteries that are known like Duracell. Next, DO NOT plug in the charger into your controller when you have AA batteries in your battery pack. Then, make sure that you press and hold the sync button of your Xbox 360 console, and your controller.
2. My wireless controller automatically turns off during gameplay...
First, make sure that you turn off the vibration of your controller, because the vibration takes away your controller's energy, and the lease power your controller will have. Next, please read the Frequently Asked Questions guide for wireless controllers, because there are some important steps about the wireless controllers. They usually have the problem with charging and changing AA batteries.
I hope that it was helpful, and if you have more questions, then you contact me at my gamertag, NussKarte. Good Luck! ;-)
SOURCE: Camera shows battery exhausted with new batteries.
I have the same problem with my coolpix L101. Even rechargeble nimh battery's with high capacity (2500 mAh) are empty after 3 shots.
SOURCE: I have a generic battery
Hi shumarsm,
If you cannot pair your PS3 controller to your PS3 you might want to consider doing this simple troubleshooting. PS3 controllers do have a memory, there's a tiny hole at the back of the controller which is the reset button. You have to stick a paperclip in or anything that you can use for it. Then, turn on your ps3, put the usb in and press the PS button. It should sync straight away.
Hope it helps.
Thank you for using Fixya.
Samsung gets their batteries from a supplier, just as newbattery gets them from their source. The OEM or original equipment manufacturer set the specifications and thus the battery was made accordingly. 30 day warranty is standard and after that, your on your own.
