Question about Sewing Machines
I have a Thompson walking foot machine. How do I change it to the zipper foot?
  • Sewing Machines Master
  • 12,731 Answers
If it is a walking foot machine, you are pretty much limited to using the walking foot. That doesn't mean you can't sew on a zipper with the walking foot, you'd just have to accommodate using the walking foot (ie if one side of the foot is narrower, place the zipper teeth on that side. It may not sew right up close to the zipper, but should still be useful). Unless there is a specific zipper foot made for your machine, it's not likely you will find one that will work.
Posted on Mar 31, 2017
SOURCE:
How to adjust my Thompson mini walking model PW - 300 pressure foot.
When I think 'higher lift' and leather - I think 'less pressure on the material' Ergo, release pressure on the pressure foot. Usually atop the left side of any machine. Press down on outer ring, to release pressure. Test on extra material. Hope this helps.
Feb 16, 2018 | Sewing Machines
I need a zipper foot for my Pfaff 1047. Where cn I find one?
Pfaff - Zipper Foot for IDT™ System (1)
www.pfaff.com/en-GB/Accessories/Zipper-Foot-for-IDT-System
The Zipper Foot is the most important zipper tool and will help you stitch the zipper perfectly in place. When attaching any zipper, it is important to sew right next ...
Pfaff - Invisible Zipper Foot
www.pfaff.com/Accessories/Invisible-Zipper-Foot Invisible zippers are the least noticeable of all zippers. As the name implies, the zipper is hidden in a seam, becoming virtually invisible. This makes it a popular ...
Pfaff 1047 Sewing Machine Parts - Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts Rating: 4.8 - ‎91,711 votes
Results 16 - 30 of 77 - An Online Pfaff Parts Superstore, We also supply 1047 manuals, presser feet and accessories. Fast, free shipping over $75. zipper foot for my Pfaff 1047 Google Search
Feb 27, 2017 | PfaFF Sewing Machines
Where would i get a zipper foot for 40 year old janome sewing machine
fortunately manufacturers take a long time to change walking feet so go to a janome sewing machine repair shop and they may have one that covers a range of years
Oct 11, 2016 | Janome Sewing Machines
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
Need a manual for a Thompson Mini Walking Foot MW-400 industrial sewing machine
google tias.com, relics and a copy your manual is $12. They have almost all of the old machine manuals. Good luck
Sep 26, 2010 | Olde Thompson Sewing Machines
When I plug my Thompson mini walking serwing machine in it's running. How do I turn it off?
Undoi the foot control and you will see a small square thing called a suppressor, take it out because it has probably blown, you do not need to replace it.
Jul 17, 2010 | Olde Thompson PW-500
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
Needles for Thompson Waling foot machine
135 X 17 is the correct sizing. Needles you should use are from #18 to #22. You can order from sailrite.com or from "thompson" the manufacturer is now datco or something, located in Lubbock Texas (do a google search on Thompson mini walking foot sewing machine)
Oct 13, 2007 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
