SOURCE: chang oil and care of filter of oil
How to change Oil>>
Step 1.
Put the bike and your tools in a convenient place. Raise the bike onto its kickstand in a clear area that can get a little dirty. Gather your new oil, tools, rags and drain pan in one place so you don't have to run to get a tool in the middle of the oil change.
Step 2.
Find the drain plug and filler cap. Before you begin to work, make sure the engine is not hot, though it should be slightly warm. Remove the filler cap so that the oil settles to the bottom of the can and can be properly drained.
Step 3.
Place your drain pan underneath the bike's drain plug. You can use a flat piece of metal, or even a piece of cardboard, to channel the oil into the drain pan.
Step 4.
Use a socket wrench to open the drain plug. Open the plug slowly so any built-up pressure can diffuse. Keep an eye on the oil's flow so you can catch as much of it as possible with the drain pan.
Step 5.
Change the oil filter. While this is not strictly necessary, it's a good idea to take the time to change the bike's oil filter. Locate the oil filter using the motorcycle's manual and replace it with a new one.
Step 6.
Replace the drain plug and refill the oil. Make sure the drain plug is securely fastened and then pour fresh oil into the tank, using the amount of oil that is specified by the bike's manual.
>>After 5000 kms you need to change the filter. Oil brand is a matter of preference as oil and filter is really a cheap price to pay so that your engine will last and last.
please rate this solution.
Thanks for using FixYa.
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
SOURCE: generac 20kw - new battery dead, twice. is there a
if this is a standby unit. there is a charger built into the control box. check the fuses. if it still blows the d\fuse you can install a float type charger available from most auto parts stores. make sure there is power comming in from the bldg breaker box.
Testimonial: "what you say is correct, however, we have checked your suggestions and the unit still will not keep a charge. we have now put a trickle charge on it"
SOURCE: chang oil light reset gmc diesel truck
if your truck doesnt have the driver info center, you can reset that by turning the key to run with the vehicle not running and push the gas pedal to the floor and let off 3 times but must be done fast
SOURCE: battery does not stay charged on my 20kw generac
WAS A 110 VOLT CIRCUIT RAN TO IT FROM THE NORMAL UTILITY POWER OF HOME OR BUILDING IT FEEDS?
NORMALLY THIS IS DONE IN A SEPERATE CONDUIT FOR CONTROL WIRES.AND THE FEEDERS ARE IN ANOTHER CONDUIT.
WITH A DIGITAL TEST METER,CHECK FOR 120 VOLTS AT THE BATTERY CHARGER IN THE GENERATOR CABINET.USUALLY THERE IS A RECEPTICAL TO PLUG THE CHARGER INTO.
IF VOLTAGE IS PRESENT AT THE BATTERY CHARGER AND INDICATOR LIGHTS ARE ON, CHANGE METER TO DC AND CHECK FOR 13.8 VOLTS OUTPUT FROM THE BATTERY CHARGER.IF YOU HAVE OUTPUT VOLTAGE TO THE BATTERY,AND IT IS DEAD,CHANGE THE BATTERY..
HOPE THIS HELPS YOU,BEST OF LUCK.....
